In Field Maps Designer, if you change the input type of a box to Text - Multiline, it doesn't actually change the appearance in ArcGIS Field Maps (other than you can press return for additional lines), it still appears as single line. If you increased the size of the box when using the multiline option, this would make life much easier for field workers when they are adding free text.
