Greetings,
I created layer in ArcGIS Pro that enables drawing order, but when I shared it to web layer and add to an online map, the drawing order is not maintained.
It's not displaying because it's considered advanced renderer settings because I used Unique Values for symbology, but then grouped categories. Otherwise the symbology is simple, just different colored dots for the different categories. The thing is, I did this for essentially the same dataset for a different geographic area several days ago and it worked just fine. I guess I should count my blessings that it worked once.
What's the workaround? Resort to creating different web layers for all of the Unique Value categories? That means I'd be creating 7 web layers instead of 1 and adding all of them to an already busy map.
Any ideas appreciated! Thanks!
