When I try to convert 11 GTFS datasets into a regional transit network dataset using the GTFS to Network Dataset tool, the attached error message shows up. It is a lot of GTFS datasets to work with but I managed to use the tool just yesterday with the same number of datasets. I only changed two of the GTFS datasets since yesterday (one only had two minor changes to the Stops file), so I don't think it's the data, but I can send the two new GTFS files just in case.
I need to have an analysis completed by Monday. If there is an issue with the tool, how promptly could this be worked out?
