I had a question regarding topology edits in Pro in comparison to Map. In Map, when there are multiple layers (line segments for addressing, and emergency service line segment layer) that need to be coincident to each other, you would make sure map topology is on first. Then, when editing the layers, Map would show you if they are all coincident or not by showing a thick pink line in the areas they are coincident and no line on the areas they are not. In Pro, it doesn't seem like this is the case anymore as even if there is a section that is not coincident, the whole line segment is selected. Although, I did add a vertex to a line segment in another instance to one layer and it automatically showed up on the other layer that was coincident to the first layer. Does Pro automatically add features to both layers that are coincident now so there is no longer the need to verify, or am I missing something? Or, is the topology feature dependent on different factors and is not a one size fits all scenario?
