I have been working on an experience that uses a Section Widget on the right side, a Map Widget with 1 map in the middle, and a Views Navigation Widget on the left.
I have a web map created with a Feature Layer that has 19 different Named Features inside its attribute table with a symbology representing each named feature.
What I want to accomplish is when I click one of the Views Navigation titles I have made on the left, I want to both 1) switch the view that has the information about the set of polygons which is the default of what the views navigation does, and 2) the idea I am proposing, an action that filters the polygons based on the named feature. Essentially, a Filter Map action inside of the views navigation that can do what a filter widget does. It will need a pan action and a zoom action, and inside of the zoom, make an automatic/custom zoom (just like the filter widget)
The current setup I have is a 2 click solution and what is being required for this experience is a 1 click solution. I believe this is achievable, as it only has to do with a views navigation interacting with a map widget. I would prefer not to need to custom build a widget in developer edition as I am not savvy.
What I have to resort to is building 20 different maps, all with the same data. Then including each "different" map with the same data inside each of the views, with a filter widget built into each view that filters the map automatically so that when you click a different view, it is a different map with an automatic filter applied to it and doesn't affect the different views as they are all not relying on a single map widget.
I have attached what I am currently workshopping. First is what all the layers look like on the opening view, Second shows what I want it to do but with the filter widget automatically applied when it opens that view. I cannot get it to automatically apply each filter in the different views as I would have to turn off the filter before I go to the next view, or else nothing shows up.
Both an idea and a current issue I am dealing with.
