I've been having issues with downloading Field Maps Designer areas on a tablet. The areas previously worked to edit offline, but when I add a layer that I recently made the area fails to download. But the map areas succeed in downloading again when I take the new layer off (even though there are old layers on the map). I can see and use all layers, including the new one, on the online Field Maps map.
I have tried making a new layer different ways, including "defining my own layer" and "selecting an existing feature layer". Each of my attempts has led to a download failure on Field Maps when the layer is added to the map. The error message for the new layer under logs after the area fails to download is: Error: Job error 7 Not found. Missing preplanned geodatabase package.
Any ideas/input would be appreciated. Thank you.
