I've seen code online that is super basic that can open the Catalog pane on the Project tab. I'm curious if there is a similar way to open the Catalog pane onto the Portal tab and auto-select "My Organization".
Code is below. Can something be placed into the parameters of the Execute method?
protected override void OnClick()
var commandId = "esri_core_showProjectDockPane";
var iCommand = FrameworkApplication.GetPlugInWrapper(commandId) as ICommand;
if (iCommand != null)
iCommand.Execute(null);
else
MessageBox.Show("Command not found: " + commandId, "Error", MessageBoxButton.OK, MessageBoxImage.Error);
