Hi @JeffSmith ,
We're facing the same or a similar issue as described in the linked post. We are on ArcGIS Enterprise 11.3.
Our custom JavaScript application uses the IdentityManager to authenticate against our Enterprise Portal. However, the esri_aopc cookie is never created. Embedding Dashboards and Scene Viewer within our application via iframes works fine, but embedding StoryMaps via an iframe always results in a login screen.
When the user clicks the login button, the StoryMap fails to load and the login screen is shown again. On the second attempt, the StoryMap opens in a new browser tab with an error.
In the browser's developer tools, I can see that when clicking the login button the first time, login.microsoftonline.com tries to set the esri_aopc cookie — but because it's a third-party cookie (despite everything running under the same domain), it fails. I assume this happens because the login flow runs inside an iframe and is treated as third-party by the browser.
Is there any supported way to force the creation of the esri_aopc cookie during the login process via IdentityManager?
I'm also unsure whether the workaround mentioned in the linked post is considered a recommended or supported Esri approach.
Thanks in advance!
