Hi there,
I am currently trying to work with python in ArcGIS Pro and I am stuck with the "Add Spatial Join"-Tool.
I got point-features (households) and lines (ducts) connected to them. I want to transfer some of the attributes from the households to the ducts feature class.
So first, I need to da a spatial join, right?
This is my code:
#code starts
import arcpy
import sys
def main():
ducts = arcpy.GetParameterAsText(0)
houses = arcpy.GetParameterAsText(1)
try:
arcpy.AddMessage(f"Add Spatial Join:\n - Target-Layer: {ducts}\n - Join-Layer: {houses}")
arcpy.management.AddSpatialJoin(
target_features=ducts,
join_features=houses,
join_operation='JOIN_ONE_TO_ONE',
join_type='KEEP_ALL',
field_mapping='CID',
match_option='INTERSECT'
arcpy.AddMessage("Spatial Join Added successfully.")
except Exception as e:
arcpy.AddError(f"Error at 'Add Spatial Join': {e}")
if __name__ == "__main__":
main()
#code ends
When running this code, I get all the messages correctly and the tool finishes successfully but there is no spatial join added to my feature class. Is there an error in my code?
Thank you for your help!
Luca
