Hi everyone,
I am using Operations Dashboard (from my AGOL account) and a correlated Web Map. I noticed that if you use map services as layers on web map, the layer list inside OD app doesn't refresh on changes.
For example, I added a map service layer inside my web map, from which I removed different layers. Although I saved the map I still see the removed layers inside Operation Dashboard app.
Has anyone run into the same issue?
Thank you!
Roxana
