Monitor server is not connecting to any hosts. Under Admin\Logs there are recent entries with "Token is Expired", but not details as to which or what token is expired. All systems use same service account to register back to server. Another is "ArcGIS Monitor Agent is not ready"
Attempted to re-register with command line from host back to server, but stated validation exception. Assume due to there already being an existing machine with same name? If i disconnect the host, will i loose the historical data and start from ground zero?
I have restarted services, entire monitor server but still no luck. Restarted Postgres service and the existing DB seems to be good and healthy.
Out of options at this point. Let me know if you have some tricks.
