I have AGE 11.3 + Oracle 19c (with un7) + Pro3.3.2
I deleted Un dataset from Oracle and now when I copy Un dataset again from FGDB to EGDB by Copy&Paste (on *.sde - branch - default - user owner - portal connection in Pro with correct privileges) the following errors appear:
Start Time: giovedì 3 aprile 2025 18:44:07
ERROR 000260: Table not registered [RETI.UN_1323_WeightDefs]--Table not registered [RETI.UN_1323_EdgeWeights]--Table not registered [RETI.UN_1323_JunctionWeights]--Table not registered [RETI.UN_1323_ElementAssociations]--Table not registered [RETI.UN_1323_Topology]--Table not registered [RETI.UN_1323_EIDMappings]--Table not registered [RETI.UN_1323_Props]--The table was not found. [Error querying row from table RETI.UN_1323_Props]--DBMS table not found [ORA-00942: table or view does not exist] [RETI.UN_1323_Props]--The creation of the utility network failed. [RETI.Network]--Operation only allowed by the owner of the version [SDE.DEFAULT]
Failed to execute (CopyMultiple).
Failed at giovedì 3 aprile 2025 18:47:37 (Elapsed Time: 3 minutes 30 seconds)
what should be done? I hope i dont have to strart from a new clean db istance.
thank you
