Hello everyone,
We are in the process of migrating to the Utility Network, and while we have successfully mapped all network classes to their respective asset groups and asset types, we still need to determine the best approach for storing non-network data.
In our current setup (ArcGIS 10.8.1 with geometric network), we store non-network data such as special property rights (polygons), landbase datasets, cadastral data, non-spatial tables for maintenance reports etc. All this in the same enterprise geodatabase but within separate datasets. As we transition to the Utility Network, we want to follow best practices for storing this type of data in the new environment.
Specifically, we are looking for guidance on:
- Database structure: Should non-network data be stored in the same database as the Utility Network but in a separate dataset, or is it better to use a separate database?
- Versioning: We plan to use branch versioning for all data, not just Utility Network feature classes. However, some of these non-network datasets require versioning, while others do not. What is the recommended approach for handling versioning in such cases?
Any insights or best practices from those who have handled similar migrations would be greatly appreciated.
Thanks in advance!
