Apologies for my ignorance (in my defense I'm not a real coder) But can anyone tell me why this very simple script doesn't print the filename when I run the script from the Toolbox. I get the string so my AddMessage is working but not the filename
import arcpy
from sys import argv
def Model(RSI_TileSets="RSI_TileSets", Output_Feature_Class="C:\\Users\\john.oliver\\Documents\\ArcGIS\\Projects\\MyProject21\\MyProject21.gdb\\RSI_TileSets_CopyFeatures"😞 # Model
# To allow overwriting outputs change overwriteOutput option to True.
# Process: Copy Features (Copy Features) (management)
arcpy.management.CopyFeatures(in_features=RSI_TileSets.__str__().format(**locals(),**globals())if isinstance(RSI_TileSets, str) else RSI_TileSets, out_feature_class=Output_Feature_Class.__str__().format(**locals(),**globals())if isinstance(Output_Feature_Class, str) else Output_Feature_Class)
inFile = arcpy.GetParameterAsText(0)
arcpy.AddMessage("{0} completed.".format(inFile))
if __name__ == '__main__':
# Global Environment settings
with arcpy.EnvManager(scratchWorkspace="C:\\Users\\john.oliver\\Documents\\ArcGIS\\Projects\\MyProject21\\MyProject21.gdb", workspace="C:\\Users\\john.oliver\\Documents\\ArcGIS\\Projects\\MyProject21\\MyProject21.gdb"😞
Model(*argv[1:])
