I previously was using arcGIS Online 4.22 javascript to upload a shape files. With the upgrade to 4.23 the same shape file now fails after the editor widget renders it on the map This error also occurs on the latest version of 4.31. The shapefile will be seen on the arcGIS Online map, but the application itself breaks after the error message is thrown. The error causes the map to break. The error message throw is "Error: div had a div child added, but there is now more than one. You must add unique key properties to make them distinguishable." If I remove the editor widget out of the code the error isn't displayed. Therefore I believe there is something internal to the editor widget's SDK that is causing the error.
at u (4.23/:2344:303)
at h (4.23/:2351:382)
at h (4.23/:2351:82)
The error message is only thrown when there is more than one shape file uploaded. If there is only a single shape file uploaded nothing breaks. After the second layer is added the error message occurs.
Here are snippets of the code I am using.
function setupEditor(view) {
// Initialize the Editor widget
const editor = new Editor({
view: view
// If the webmap already contains layers with templates,
// Editor will pick them up automatically.
function addShapefileToMap(featureCollection) {
let sourceGraphics = [];
const layers = featureCollection.layers.map((layer) => {
const graphics = layer.featureSet.features.map((feature) => {
return Graphic.fromJSON(feature);
sourceGraphics = sourceGraphics.concat(graphics);
const featureLayer = new FeatureLayer({
objectIdField: "FID",
source: graphics,
fields: layer.layerDefinition.fields.map((field) => {
return Field.fromJSON(field);
featureLayer.userUploaded = true;
return featureLayer;
webmap.addMany(layers);
I have provided the simple shapefile example that I have used.
featureCollection:
"layers": [
"layerDefinition": {
"currentVersion": 11.2,
"id": 0,
"name": "PolygonFootballFID",
"type": "Feature Layer",
"displayField": "",
"description": "",
"copyrightText": "",
"defaultVisibility": true,
"relationships": [],
"isDataVersioned": false,
"supportsAppend": true,
"supportsCalculate": true,
"supportsASyncCalculate": true,
"supportsTruncate": false,
"supportsAttachmentsByUploadId": true,
"supportsAttachmentsResizing": true,
"supportsRollbackOnFailureParameter": true,
"supportsStatistics": true,
"supportsExceedsLimitStatistics": true,
"supportsAdvancedQueries": true,
"supportsValidateSql": true,
"supportsCoordinatesQuantization": true,
"supportsLayerOverrides": true,
"supportsTilesAndBasicQueriesMode": true,
"supportsFieldDescriptionProperty": true,
"supportsQuantizationEditMode": true,
"supportsApplyEditsWithGlobalIds": false,
"supportsMultiScaleGeometry": true,
"supportsReturningQueryGeometry": true,
"advancedQueryCapabilities": {
"supportsPagination": true,
"supportsQueryAttachmentsCountOnly": true,
"supportsPaginationOnAggregatedQueries": true,
"supportsQueryRelatedPagination": true,
"supportsQueryWithDistance": true,
"supportsReturningQueryExtent": true,
"supportsOrderBy": true,
"supportsDistinct": true,
"supportsQueryWithResultType": true,
"supportsSqlExpression": true,
"supportsTimeRelation": true,
"supportsAdvancedQueryRelated": true,
"supportsCountDistinct": true,
"supportsPercentileStatistics": true,
"supportsApproxPercentileStatistics": true,
"supportsSpatialAggregationStatistics": true,
"supportsTrueCurve": true,
"supportedSpatialAggregationStatistics": [
"EnvelopeAggregate",
"CentroidAggregate",
"ConvexHullAggregate"
"supportsReturningGeometryCentroid": true,
"supportsReturningGeometryEnvelope": true,
"supportsReturningGeometryProperties": true,
"supportsQueryWithDatumTransformation": true,
"supportsCurrentUserQueries": true,
"supportsHavingClause": true,
"supportsOutFieldSQLExpression": true,
"supportsMaxRecordCountFactor": true,
"supportsTopFeaturesQuery": true,
"supportsDisjointSpatialRel": true,
"supportsQueryWithCacheHint": true,
"supportedOperationsWithCacheHint": [
"query",
"queryTopFilter",
"queryAnalytics",
"queryAttachments",
"queryRelated",
"queryBins"
"supportsQueryAnalytic": true,
"supportsDefaultSR": true,
"supportsFullTextSearch": true,
"supportsFullTextAccentSensitivity": true,
"supportsFullTextStopWords": true
"advancedQueryAnalyticCapabilities": {
"supportsLinearRegression": true,
"supportsAsync": true,
"supportsPercentileAnalytic": true
"advancedEditingCapabilities": {
"supportedSqlFormatsInCalculate": [
"standard"
"supportsAsyncApplyEdits": true,
"supportsReturnEditResults": true,
"supportsApplyEditsbyUploadID": true,
"supportedApplyEditsUploadIDFormats": "JSON"
"infoInEstimates": [
"extent",
"count"
"useStandardizedQueries": false,
"geometryType": "esriGeometryPolygon",
"minScale": 0,
"maxScale": 0,
"extent": {
"xmin": -13511597.50077992,
"ymin": 6066247.558067595,
"xmax": -13510807.236089986,
"ymax": 6067610.137463532,
"spatialReference": {
"wkid": 102100,
"latestWkid": 3857
"drawingInfo": {
"renderer": {
"type": "simple",
"symbol": {
"type": "esriSFS",
"style": "esriSFSSolid",
"color": [
76,
129,
205,
191
"outline": {
"type": "esriSLS",
"style": "esriSLSSolid",
"color": [
0,
0,
0,
255
"width": 0.75
"transparency": 0,
"labelingInfo": null
"allowGeometryUpdates": true,
"supportedCurveTypes": [
"esriGeometryCircularArc"
"allowTrueCurvesUpdates": false,
"onlyAllowTrueCurveUpdatesByTrueCurveClients": false,
"hasAttachments": false,
"htmlPopupType": "",
"hasM": false,
"hasZ": false,
"objectIdField": "FID",
"globalIdField": "",
"typeIdField": "",
"fields": [
"name": "FID",
"type": "esriFieldTypeOID",
"alias": "FID",
"sqlType": "sqlTypeOther",
"nullable": false,
"editable": false,
"domain": null,
"defaultValue": null
"name": "FID_1",
"type": "esriFieldTypeSmallInteger",
"alias": "FID_1",
"nullable": true,
"editable": true,
"domain": null,
"name": "Name",
"type": "esriFieldTypeString",
"alias": "Name",
"length": 14,
"nullable": true,
"editable": true,
"domain": null,
"indexes": [],
"dateFieldsTimeReference": {
"timeZone": "UTC",
"respectsDaylightSaving": false
"preferredTimeReference": null,
"types": [],
"templates": [
"name": "New Feature",
"description": "",
"drawingTool": "esriFeatureEditToolPolygon",
"prototype": {
"attributes": {
"FID_1": null,
"Name": null
"supportedQueryFormats": "JSON, geoJSON, PBF",
"supportedAppendFormats": "sqlite,geoPackage,shapefile,filegdb,featureCollection,geojson,csv,excel,jsonl,featureService,pbf",
"supportedAppendSourceFilterFormats": "sqlite,geoPackage,shapefile,filegdb,featureService",
"supportedExportFormats": "csv,shapefile,sqlite,geoPackage,filegdb,featureCollection,geojson,kml,excel",
"supportedConvertFileFormats": "JSON,PBF",
"supportedConvertContentFormats": "LayerEditCollection,FeatureCollection",
"supportedSpatialRelationships": [
"esriSpatialRelIntersects",
"esriSpatialRelContains",
"esriSpatialRelCrosses",
"esriSpatialRelEnvelopeIntersects",
"esriSpatialRelIndexIntersects",
"esriSpatialRelOverlaps",
"esriSpatialRelTouches",
"esriSpatialRelWithin",
"esriSpatialRelDisjoint",
"esriSpatialRelRelation"
"supportedContingentValuesFormats": "JSON, PBF",
"supportedSyncDataOptions": 260,
"hasStaticData": false,
"maxRecordCount": -1,
"standardMaxRecordCount": 4000,
"standardMaxRecordCountNoGeometry": 32000,
"tileMaxRecordCount": 4000,
"maxRecordCountFactor": 1,
"capabilities": "Create,Delete,Query,Update,Editing"
"featureSet": {
"features": [
"attributes": {
"FID": 0,
"FID_1": 3,
"Name": "FootballField1"
"geometry": {
"wkid": 102100,
"latestWkid": 3857
"rings": [
-13511597.5007799,
6067597.59357956
-13511401.5025929,
6067610.13746353
-13511401.5025929,
6067610.13746353
-13511409.3425204,
6067605.43350704
-13511385.822738,
6067522.33027576
-13511586.5248814,
6067500.37847882
-13511597.5007799,
6067597.59357956
"attributes": {
"FID": 1,
"FID_1": 4,
"Name": "FootballField2"
"geometry": {
"wkid": 102100,
"latestWkid": 3857
"rings": [
-13511023.6180884,
6066413.76453016
-13510858.9796114,
6066434.14834161
-13510807.23609,
6066283.621734
-13510998.5303205,
6066247.55806759
-13511023.6180884,
6066413.76453016
"id": 1,
"name": "PolygonParksFID",
"displayField": "",
"description": "",
"query",
"queryTopFilter",
"queryAnalytics",
"queryAttachments",
"queryRelated",
"queryBins"
"standard"
"extent",
"count"
"minScale": 0,
"maxScale": 0,
"extent": {
"xmin": -13512034.96873328,
"ymin": 6065179.759944892,
"xmax": -13509958.955936708,
"ymax": 6067904.918736763,
"wkid": 102100,
"latestWkid": 3857
"drawingInfo": {
"renderer": {
"type": "simple",
"symbol": {
"type": "esriSFS",
"color": [
252,
225,
56,
191
"outline": {
"type": "esriSLS",
"color": [
0,
0,
0,
255
"width": 0.75
"transparency": 0,
"hasM": false,
"hasZ": false,
"typeIdField": "",
"fields": [
"name": "FID",
"alias": "FID",
"nullable": false,
"editable": false,
"domain": null,
"name": "FID_1",
"type": "esriFieldTypeInteger",
"alias": "FID_1",
"nullable": true,
"editable": true,
"domain": null,
"name": "Name",
"alias": "Name",
"length": 80,
"nullable": true,
"editable": true,
"domain": null,
"indexes": [],
"timeZone": "UTC",
"types": [],
"templates": [
"description": "",
"prototype": {
"attributes": {
"FID_1": null,
"Name": null
"featureSet": {
"features": [
"attributes": {
"FID": 0,
"FID_1": 1,
"Name": "Park1"
"geometry": {
"wkid": 102100,
"latestWkid": 3857
"rings": [
-13511357.598999,
6065869.67356308
-13511138.0810296,
6066609.76271715
-13511037.7299579,
6066634.85048508
-13511044.0018999,
6066641.12242707
-13511050.2738419,
6066634.85048508
-13511050.2738419,
6066634.85048508
-13509958.9559367,
6066126.82318441
-13510837.0278144,
6065179.75994489
-13511357.598999,
6065869.67356308
"attributes": {
"FID": 1,
"FID_1": 2,
"Name": "Parks2"
"geometry": {
"wkid": 102100,
"latestWkid": 3857
"rings": [
-13511818.5867348,
6067559.96192767
-13512034.9687333,
6067835.92737495
-13511661.7881853,
6067864.15111387
-13511370.142883,
6067904.91873676
-13511031.4580159,
6067901.78276577
-13511210.2083624,
6067892.3748528
-13511229.0241884,
6067813.975578
-13510448.1674114,
6067707.35256428
-13510178.4739061,
6067431.387117
-13510303.9127458,
6067089.5662789
-13511746.459402,
6066882.59219344
-13511818.5867348,
6067559.96192767
"showLegend": true
Layers:
"id": "19484f1fc15-layer-38",
"showLegend": true,
"listMode": "show",
"disablePopup": false,
"title": "Layer",
"visibility": true,
"layerType": "ArcGISFeatureLayer",
"refreshInterval": 0,
"minScale": 0,
"maxScale": 0,
"definitionExpression": null,
"featureReduction": null
"timeAnimation": true,
"showLabels": true,
"screenSizePerspective": true
"id": "19484f1fc17-layer-39",
"showLegend": true,
"listMode": "show",
"title": "Layer",
"visibility": true,
"minScale": 0,
"maxScale": 0,
"showLabels": true,
SourceGraphis:
"aggregateGeometries": null,
"geometry": {
"latestWkid": 3857,
"wkid": 102100
"rings": [
-13511597.5007799,
6067597.59357956
-13511401.5025929,
6067610.13746353
-13511401.5025929,
6067610.13746353
-13511409.3425204,
6067605.43350704
-13511385.822738,
6067522.33027576
-13511586.5248814,
6067500.37847882
-13511597.5007799,
6067597.59357956
"symbol": null,
"attributes": {
"FID": 0,
"FID_1": 3,
"popupTemplate": null
"geometry": {
"latestWkid": 3857,
"wkid": 102100
"rings": [
-13511023.6180884,
6066413.76453016
-13510858.9796114,
6066434.14834161
-13510807.23609,
6066283.621734
-13510998.5303205,
6066247.55806759
-13511023.6180884,
6066413.76453016
"symbol": null,
"attributes": {
"FID": 1,
"FID_1": 4,
"geometry": {
"latestWkid": 3857,
"wkid": 102100
"rings": [
-13511357.598999,
6065869.67356308
-13511138.0810296,
6066609.76271715
-13511037.7299579,
6066634.85048508
-13511044.0018999,
6066641.12242707
-13511050.2738419,
6066634.85048508
-13511050.2738419,
6066634.85048508
-13509958.9559367,
6066126.82318441
-13510837.0278144,
6065179.75994489
-13511357.598999,
6065869.67356308
"symbol": null,
"attributes": {
"FID": 0,
"FID_1": 1,
"Name": "Park1"
"geometry": {
"latestWkid": 3857,
"wkid": 102100
"rings": [
-13511818.5867348,
6067559.96192767
-13512034.9687333,
6067835.92737495
-13511661.7881853,
6067864.15111387
-13511370.142883,
6067904.91873676
-13511031.4580159,
6067901.78276577
-13511210.2083624,
6067892.3748528
-13511229.0241884,
6067813.975578
-13510448.1674114,
6067707.35256428
-13510178.4739061,
6067431.387117
-13510303.9127458,
6067089.5662789
-13511746.459402,
6066882.59219344
-13511818.5867348,
6067559.96192767
"symbol": null,
"attributes": {
"FID": 1,
"FID_1": 2,
"Name": "Parks2"
Any help is appreciated!
