I am setting up a Field Maps form through the Field Maps Designer and have two field that have dynamic visibility set. On start up both fields should be shown and then once one is populated the other should be hidden (as only one of the fields needs to be populated by the user). When I view the form in field maps this works fine, however when viewing the form in Map Viewer neither of the fields are shown when the form is opened. Meaning no data can be entered to these fields.
Has anyone else had issues with dynamic visibility for fields in Map Viewer?
Any help would be really appreciated. Thank you
