This is basically a drop in replacement for some really inscrutable code in the utils module that's used to translate string literal arguments to integer flags using an Adaptor implementation (see _mp.constants).
It is possible to use inspect now to directly override __annotations__ for a function and since this class will always be a converting string literals to integers (or other strings) using the __args__ class attribute, it's possible to generate Literal types using that mapping using the __init_subclass__ method to generate them on the fly for implemented Adaptor classes:
def __init_subclass__(cls, **kwargs):
""" Build Literals for the subclass and formats the __args__ dictionary to lowercase """
# Lowercase the keys for case insensitivity
cls.__args__ = {k.lower(): v for k, v in cls.__args__.items()}
# Build the literals for the subclass
cls.__hints__: ArgAdaptor.HintMap = {
parameter: Literal[*list(options.keys())]
for parameter, options in cls.__args__.items()
You can then directly update the __annotations__ attribute of the wrapper function:
# Apply literal type hints to the adapted function
adapt_arguments.__annotations__.update(adaptor.__hints__)
# Allow manual annotations to override the literal type hints
adapt_arguments.__annotations__.update(masked_function.__annotations__)
This will add the option keys as Literal hints for each masked parameter:
# Toy example with some basic masking keys
>>> Testing.maskedFunction.__annotations__
>>> ('format', typing.Literal['pdf', 'svg', 'eps'])
>>> ('mode', typing.Literal['read', 'write', 'execute'])
>>> ('filename', <class 'str'>)
instead of that __annotation__ attribute only being the hints written directly into the function header.
This allows for Literal hinting to be applied with no extra work for any functions wrapped by ArgAdaptor. It will also update the hints at runtime after changes to the __args__ attribute of an implementation class.
Code:
Spoilerimport functools
from typing import Callable, Sequence, Any, TypeAlias, Literal
import inspect
class ArgAdaptor:
ValueMap: TypeAlias = dict[str, str | int]
ArgumentMap: TypeAlias = dict[str, ValueMap]
HintMap: TypeAlias = dict[str, TypeAlias]
__args__: ArgumentMap = {}
@classmethod
def maskargs(adaptor: 'ArgAdaptor', masked_function: Callable) -> Callable:
masked_function_signature = inspect.signature(masked_function)
function_parameters = masked_function_signature.parameters
adaptors = adaptor.__args__
@functools.wraps(masked_function)
def adapt_arguments(*args, **kwargs):
adapted_arguments: dict[str, Any] = {
parameter.name: value
for parameter, value in zip(function_parameters.values(), args)
if parameter.kind in (
inspect.Parameter.POSITIONAL_ONLY,
inspect.Parameter.POSITIONAL_OR_KEYWORD,
inspect.Parameter.VAR_POSITIONAL
adapted_arguments.update(kwargs)
invalid_args: list[Exception] = []
for argument, arg_value in adapted_arguments.items():
if argument not in adaptors:
continue
elif isinstance(arg_value, str):
arg_value = arg_value.lower()
if arg_value not in adaptors[argument]:
invalid_args.append(
f'Invalid value for `{argument}`: '
f"'{arg_value}' "
f'(choices are {list(adaptors[argument].keys())})'
continue
adapted_arguments[argument] = adaptors[argument][arg_value]
elif isinstance(arg_value, Sequence):
arg_values: list[str] = arg_value
invalid_values = [
arg_val
for arg_val in arg_values
if arg_val not in adaptors[argument]
if invalid_values:
f'Invalid value{"s"*(len(invalid_values)>1)} for {argument}:'
f'{", ".join(map(str, invalid_values))}'
continue
adapted_arguments[argument] = [
adaptors[argument][arg_val.lower()]
if invalid_args:
raise ValueError('\n'.join(invalid_args))
return masked_function(**adapted_arguments)
for att in ('__doc__', '__annotations__', '__esri_toolinfo__'):
setattr(
adapt_arguments,
att,
getattr(adapt_arguments, att, None) or
getattr(masked_function, att, None) or
f"String::"
f"{'|'.join(adaptors[argument].keys())}:"
for argument in function_parameters.keys()
if argument in adaptors
if att == '__esri_toolinfo__'
else None
return adapt_arguments
@classmethod
def maskmethods(adaptor: 'ArgAdaptor', other: type) -> None:
# Grab all non dunder/private methods
methods_to_mask = {
method_name: method_object
for method_name in dir(other)
# Check if the method is callable and not private
# Use the walrus operator to store the method object
if callable(method_object := getattr(other, method_name))
and not method_name.startswith("_")
# Mask the methods using the specified adaptor
for method_name, method_object in methods_to_mask.items():
setattr(other, method_name, adaptor.maskargs(method_object))
print(f'Masked method: {method_name}')
This code is not fully compliant with the original implementation as there were some instance specific concatenations and overrides, but I think this is a good starting point for making this adapter class more clear and extensible. This could be an alternative to maintaining a bunch of separate type hints as well.
