Hello!
I'm working with the arcgis API for Python, but I'm having some serious issues getting it to work as expected.
I'm using portal-tier authentication.
First I try loading a Web Map directly. That gives me the following error.
from arcgis.gis import GIS
portal = GIS(url="https://maps.xyz.com/portal", username="xyz", password="xyz")
web_map_id = 'xyz'
web_map = portal.content.get(web_map_id)
portal.map(web_map)
ValidationError: 3680 validation errors for Webmap
operationalLayers.5.AnnotationLayerArcGISAnnotationLayer.layerType
Input should be 'ArcGISAnnotationLayer' [type=literal_error, input_value='ArcGISMapServiceLayer', input_type=str]
For further information visit https://errors.pydantic.dev/2.4/v/literal_error
operationalLayers.5.CatalogLayerCatalogLayer.layerType
Input should be 'CatalogLayer' [type=literal_error, input_value='ArcGISMapServiceLayer', input_type=str]
operationalLayers.5.CSVLayerCSV.layerType
Input should be 'CSV' [type=literal_error, input_value='ArcGISMapServiceLayer', input_type=str]
operationalLayers.5.DimensionLayerArcGISDimensionLayer.layerType
Field required [type=missing, input_value={'id': 911, 'layerDefinit...efaultVisibility': True}, input_type=dict]
For further information visit https://errors.pydantic.dev/2.4/v/missing
operationalLayers.5.LinkChartLayerLinkChartLayer.layerType
Input should be 'LinkChartLayer' [type=literal_error, input_value='ArcGISMapServiceLayer', input_type=str]
Subsequently, I tried starting with an empty map, and loading Feature Layers directly
from arcgis.layers import Service
layers = Service(
"https://xyz.com/arcgis/rest/services/xyz/xyz/FeatureServer"
m = portal.map()
m.basemap.basemap = 'satellite'
for lyr in layers.layers:
m.content.add(lyr)
m.center = [xyz, xyz]
m.zoom = 30That just outputs the basemap, with no layers to be seen.
Printing `layers` gives the following
<FeatureLayerCollection url:"https://xyz.com/arcgis/rest/services/xyz/xyz/FeatureServer">
Is this maybe a permission issue? I have no other ideas left. I've followed the guides in the documentation.
Also, this is all on version 2.4.0
Cheers.
