Hello! After updating our ArcGIS deployment from 11.3 to 11.4 we no longer can take backups using webgisdr tool. Upgrade was done using cloudformation template provided by Esri. To take backup I run:
opt/arcgis/portal/tools/webgisdr/webgisdr.sh --export --file /opt/arcgis/portal/tools/webgisdr/webgisdr.properties
As a result I receive:
Starting the WebGIS DR utility.
Exception in thread "main" java.lang.NoClassDefFoundError: com/azure/storage/file/datalake/models/DataLakeStorageException
at com.esri.arcgis.discovery.cache.AccessCredentials$Provider.fromStringIgnoreCase(AccessCredentials.java)
at com.esri.arcgis.discovery.util.CloudEndpointLocator.b(CloudEndpointLocator.java:218)
at com.esri.arcgis.discovery.util.CloudEndpointLocator.getProperty(CloudEndpointLocator.java:133)
at com.esri.arcgis.discovery.util.CloudEndpointLocator.getS3EndPoint(CloudEndpointLocator.java:50)
at com.esri.arcgis.webgis.storageservice.s3.S3StorageService.a(S3StorageService.java:215)
at com.esri.arcgis.webgis.storageservice.s3.S3StorageService.<init>(S3StorageService.java:164)
at com.esri.arcgis.webgis.storageservice.s3.S3StorageProvider.connect(S3StorageProvider.java:19)
at com.esri.arcgis.webgis.storageservice.StorageManager.getConnection(StorageManager.java:63)
at com.esri.arcgis.webgis.service.impl.WebGISDRFrontController.service(WebGISDRFrontController.java:132)
at com.esri.arcgis.webgis.service.impl.WebGISDRManager.b(WebGISDRManager.java:193)
at com.esri.arcgis.webgis.service.impl.WebGISDRManager.exportWebGIS(WebGISDRManager.java:177)
at com.esri.arcgis.webgis.client.WebGISDR.main(WebGISDR.java:138)
Caused by: java.lang.ClassNotFoundException: com.azure.storage.file.datalake.models.DataLakeStorageException
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
... 12 more
I guess I may be missing some properties from my webgisdr.properties file because I replaced original webgisdr.properties by the same file from 11.3. I tried to recreate it manually using properties from https://enterprise.arcgis.com/en/portal/latest/administer/linux/populate-webgisdr-tool-properties-file.htm but no success, I still receive same error.
