Hi all, I can't seem to figure out how to add my output layers to my current map display through my python toolbox code. Anyone have any idea how to do so?
import arcpy
import pandas as pd
from arcpy.sa import *
class Toolbox(object):
def __init__(self):
self.label = "Mapping Trees Model"
self.alias = "mapping trees"
# List of tool classes associated with this toolbox
self.tools = [MappingTrees]
class MappingTrees(object):
def __init__(self):
self.description = "This model analyzes information from a raster with tree data such as tree height, canopy cover percent, etc. for an area of interest defined by the user. "
def getParameterInfo(self):
#Define the parameters
Extent = arcpy.Parameter(
displayName = "Define Extent",
name = "Extent",
datatype = "GPExtent",
parameterType = "Required",
direction = "Input")
Identify_Workspace = arcpy.Parameter(
displayName = "Identify Workspace",
name = "Identify_Workspace",
datatype = "DEWorkspace",
Study_Area = arcpy.Parameter(
displayName="Study Area",
name="Study_Area",
datatype="GPFeatureLayer",
parameterType="Required",
direction="Input")
Study_Area.controlCLSID = "{60061247-BCA8-473E-A7AF-A2026DDE1C2D}"
Base_Raster = arcpy.Parameter(
displayName="Base Tree Raster (such as tree height, canopy cover percentage, etc.)",
name="Base_Raster",
datatype="GPRasterLayer",
direction="Input")
#Base_Raster.filter.type = "ValueList"
dBASE_file = arcpy.Parameter(
displayName = "Class Ranges (dBASE file)",
name = "dBASE_file",
datatype = "GPTableView",
## Patches = arcpy.Parameter(
## displayName = "Raster to Polygon",
## name = "Patches",
## datatype = "GPLayer",
## parameter = "Derived",
## direction = "Output")
parameters = [Extent, Identify_Workspace, Study_Area, Base_Raster, dBASE_file]
return parameters
def isLicensed(self):
try:
if arcpy.CheckExtension("Spatial") != "Available":
raise Exception
else:
except Exception:
arcpy.AddMessage('Spatial Analyst Extension not available')
return False # tool cannot be executed
return True # tool can be executed
def updateParameters(self, parameters):
return
def updateMessages(self, parameters):
return
def execute(self, parameters, messages):
#allow tool to overwrite the layers in the file being used
arcpy.env.overwriteOutput == True
#Make it so I can use the parameters in the tool
Extent = parameters[0].valueAsText
Identify_Workspace = parameters[1].valueAsText
Study_Area = parameters[2].valueAsText
Base_Raster = parameters[3].valueAsText
dBASE_file = parameters[4].valueAsText
#Define workspace
arcpy.env.workspace = Identify_Workspace
# Extract by Mask: extract out the study area out of the base raster
Extract_Mask = "Extract_Raster.tif"
Extract_Mask1 = arcpy.sa.ExtractByMask(Base_Raster, Study_Area, "INSIDE")
Extract_Mask1.save(Extract_Mask)
# Reclassify: classify a raster with the range of what you would like it to be
array = arcpy.da.TableToNumPyArray(dBASE_file, "*")
df = pd.DataFrame(array)
class_list = df.values.tolist()
for i in range(len(class_list)):
class_list[i] = class_list[i][1:-1]
myRemapRange = arcpy.sa.RemapRange(class_list)
User_Reclassified_Raster = "User_Reclassified_Raster.tif"
reclassified_raster = arcpy.sa.Reclassify(Extract_Mask1, "Value", myRemapRange, "NODATA")
reclassified_raster.save(User_Reclassified_Raster)
# Add Field: add the field Range to the reclassified raster
# to help user know what ranges go with what classified value
arcpy.management.AddField(User_Reclassified_Raster, "Range", "TEXT", field_alias = "Height Range")
# Join Field: join the from and to fields from the dBASE file
arcpy.management.JoinField(User_Reclassified_Raster, "Value", dBASE_file, "OUT",["FROM_", "TO"])
# Calculate Field
arcpy.management.CalculateField(User_Reclassified_Raster,"Range", "\"!FROM_! - !TO!\"")
# Delete Field
arcpy.management.DeleteField(User_Reclassified_Raster, ["FROM_", "TO"])
#List the fields in the Study Area polygon and if it does not have the fild ID, add it
fields = arcpy.ListFields(Study_Area)
if "Id" not in fields:
arcpy.management.AddField(Study_Area, "Id", "LONG")
arcpy.management.CalculateField(Study_Area, "Id", 0)
# Tabulate Area: calculate the area of each range of heights, etc.
Tabulate_Area = "Tabulate_Area.dbf"
arcpy.sa.TabulateArea(User_Reclassified_Raster, "Range", Study_Area, "Id", Tabulate_Area, User_Reclassified_Raster, "CLASSES_AS_FIELDS")
# Join, Add Field, Calculate Field, Delete Field: the tabulate area table to the reclassified raster, then add and calculate
# the field Area so one knows what field they are looking at, Delete the field "ID_0"
arcpy.management.JoinField(User_Reclassified_Raster, "Range", Tabulate_Area, "RANGE", ["ID_0"])
arcpy.management.AddField(User_Reclassified_Raster, "Area", "DOUBLE")
arcpy.management.CalculateField(User_Reclassified_Raster, "Area", "!ID_0!")
arcpy.management.DeleteField(User_Reclassified_Raster, "ID_0")
# Raster to Polygon: convert the reclassified raster to polygons
R2P = "R2P"
arcpy.conversion.RasterToPolygon(User_Reclassified_Raster, R2P,"NO_SIMPLIFY", "Range")
# Dissolve: combine all the polygons together that touch
Dissolve_Polys = "Dissolve_Polys"
arcpy.management.Dissolve(R2P, Dissolve_Polys, "", "", "SINGLE_PART")
#Eliminate: smooth out the polygons
Patches = "Patches"
arcpy.management.EliminatePolygonPart(Dissolve_Polys, Patches, "AREA", 1000)
# Zonal Statistics: calculate the statistics (min, max, and mean) of the tree values
ZonalStats = "ZonalStats.dbf"
arcpy.sa.ZonalStatisticsAsTable(Patches, "ORIG_FID", Base_Raster, ZonalStats, "DATA", "MIN_MAX_MEAN")
# Join Field: join the zonal stats fields to the smoothed out polygons
arcpy.management.JoinField(Patches, "ORIG_FID", ZonalStats, "ORIG_FID", ["AREA", "MIN", "MAX", "MEAN"])
arcpy.management.DeleteField(Patches, ["Id", "ORIG_FID"])
arcpy.management.AddField(Patches, "Acres", "DOUBLE")
arcpy.management.CalculateGeometryAttributes(Patches, [["Acres","AREA"]], area_unit="ACRES_US")
# Delete: delete the following layers:
arcpy.management.Delete(Extract_Mask1)
arcpy.management.Delete(R2P)
arcpy.management.Delete(Dissolve_Polys)
arcpy.management.Delete(ZonalStats)
arcpy.management.Delete(Tabulate_Area)
c_project=arcpy.mp.ArcGISProject("CURRENT")
return
def postExecute(self, parameters):
return
