Is it possible to apply dynamic colouring to vector data (points)?
I haven't found this as a built-in function, so I assume there could be some ArcGIS Arcade expressions for this. The idea is that as the user zooms in on the map, the points change colour, for example, from red to green based on some numeric values/numeric column.
The goal is to have this dynamic colouring in a web map that is used in a Dashboard.
We are using Enterprise 11.2.
