Hey everyone,
after upgrading to angular 19 i am getting the follow error trying to serve the application:
✘ [ERROR] The package "path" wasn't found on the file system but is built into node. [plugin angular-browser-node-built-in]
node_modules/@arcgis/core/chunks/pe-wasm.js:31:20:
31 │ b = require("path");
✘ [ERROR] The package "fs" wasn't found on the file system but is built into node. [plugin angular-browser-node-built-in]
node_modules/@arcgis/core/chunks/pe-wasm.js:30:22:
30 │ var u = require("fs"),
/Users/user/Desktop/Projekte/project/applications/frontend-mono/node_modules/vite/node_modules/esbuild/lib/main.js:1472
let error = new Error(text);
Error: Build failed with 2 errors:
node_modules/@arcgis/core/chunks/pe-wasm.js:30:22: ERROR: [plugin: angular-browser-node-built-in] The package "fs" wasn't found on the file system but is built into node.
node_modules/@arcgis/core/chunks/pe-wasm.js:31:20: ERROR: [plugin: angular-browser-node-built-in] The package "path" wasn't found on the file system but is built into node.
at failureErrorWithLog (/Users/user/Desktop/Projekte/project/applications/frontend-mono/node_modules/vite/node_modules/esbuild/lib/main.js:1472:15)
at /Users/user/Desktop/Projekte/project/applications/frontend-mono/node_modules/vite/node_modules/esbuild/lib/main.js:945:25
at /Users/user/Desktop/Projekte/project/applications/frontend-mono/node_modules/vite/node_modules/esbuild/lib/main.js:1353:9
at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
errors: [Getter/Setter],
warnings: [Getter/Setter]
I am using nx: "20.2.1", angular "19.0.4", with "executor": "@nx/angular:dev-server", as executor arcgis: "4.31.6", and "skipLibCheck": "true". Any help would be appreciated 🙂
