Hey all,
Our Enterprise environment has been running well for a while, but due to an increase of users, the site is starting to struggle.
ArcGIS Portal has started showing signs of growing pains, the feature layers typically take upwards of 2 minutes to load fully, then lag when the view is moved around. These are pretty large feature layers, with quite a lot of symbology though.
In terms of hardware upgrades, what should be upgraded? CPU, RAM, etc. Along with this, what servers should receive these upgrades?
I have ArcGIS Monitor installed on all servers, ArcGIS Server will regularly top out at 100% CPU usage, this is after an additional two cores were added in. ArcGIS Portal is relatively tame, never really topping out, but actively spiking.
TLDR; What component should I upgrade on what sever.
Server: 16GB RAM, 2 sockets 4 cores 2.30GHz
Portal: 16GB RAM, 1 socket 2 cores 2.30Ghz
SQL: 32GB RAM, 1 socket 2 cores 2.30GHz
Thanks in advance!
Cody
