Hi,I have inherited an ArcGIS JavaScript API project. I am very new to this API in particular and ArcGIS in general. Currently, one part of the code is very problematic--populating the map with some query task's results. Here is a code snippet. In the debugger I can see the returned results, including geometry of individual result rows. But they never show up on the map. function showResults(results) {//This bounds the results into the data grid from doFind() function var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 200), new dojo.Color([98,194,204,0.5])); for(var i=0; i < results.features.length; i++){ //map.graphics.add(results.features); var graphic = results.features; graphic.setSymbol(symbol); map.graphics.add(graphic); } }
What could be happening? I don't think posting thousands of line of code will help. But the debugger does show information for each row, such as:map.graphics.graphics.geometry[0]-> - _shape=null- type=point- x= 283265- y= 3955658- symbol [object data]and when I go to:http://myserver/arcgis/rest/services/NPS_Location_Search/MapServer/0then, under Drawing Info, I can see the colored dot object for Symbol.I can give more info about how the various maps are laid out if that helps?Thanks!Meengla
