I am trying to figure out how to write an arcade expression that will populate 1 field based off of the values in 4 other fields. I am using attribute rules and still very green to arcade expression. I would also like the attribute rules to work in field maps. When our field crews go out they will be filling in the 4 fields mentioned above and I am having trouble piecing this expression together.
Field Name to Auto Populate: serviceLineClassification
Field Names to Trigger Auto Populate
systemBasisOfClassification1
systemInstallationDateRange
customerBasisOfClassification1
customerInstallationDateRange
Note: All of the fields have domains connected to them. The expression I put together below is just the first of many as I need to cover all of the variables. However, I am having trouble getting the first expression together.
Expression I Tried:
if (DomainName($feature, 'systemBasisOfClassification1', 'A) Records Review', "n/a") == 'A) Records Review' && DomainName($feature, 'systeminstallationDateRange', 'n/a') == "L) 1991-2000', 'n/a')) {return DomainName($feature, 'serviceLineClassification', 'Non-Lead', 'n/a')}
Hope all of this makes sense and in advanced thanks to anyone who can help.
