I am reading rows from a database with a field "Coords" that contains polygon coordinates in the format 40.090170,-83.007704|40.089878,-83.007724..... and inserting each row as a polygon.
The first feature is drawn correctly, the second feature is drawn but is connected to and duplicates the first feature, and the third contains all three and so on.
The coordinates are cumulative (not intentionally). I tried deleting variables between iterations, but that didn't help. What am I missing?
import pypyodbc import arcpy GdbFeat = r"\\server\Arc_Server_data\publish.gdb\OUPS" spatialRef = arcpy.Describe(GdbFeat).spatialReference conn = pypyodbc.win_connect_mdb(r"C:\GIS\db\COWOUPSx.mdb") cursor = conn.cursor() cursor.execute("SELECT TicketDate, TicketNum, Coords FROM Tickets WHERE (((TicketDate) = #11/15/2014#))") rows = cursor.fetchall() cursor.close del cursor conn.close del conn if rows: polygonArray = arcpy.Array() for row in rows: Coords = row[6] coordinatePairList = Coords.split("|") for coordinatePair in coordinatePairList: coordinates = coordinatePair.split(",") currentPoint = arcpy.Point(coordinates[1],coordinates[0]) polygonArray.add(currentPoint) polygon = arcpy.Polygon(polygonArray, spatialRef) polygonArray.removeAll with arcpy.da.InsertCursor(GdbFeat, ("Shape@", "TicketDate", "TicketNum")) as Acursor: Acursor.insertRow((polygon, row[0], row[1])) del Coords del polygon del coordinatePairList del coordinatePair del coordinates del currentPoint del row del rows
