Hi
I have Field Maps based on a map which has a point layer which was originally uploaded as a geopackage and in that process converted to a feature layer. My field maps work perfectly apart from when I try to take offline.
In the Offline section - I get a warning message that "the layer is missing a global ID field and cannot be taken offline"
The layer already has a global ID field with the name of "globalid"
The "Enable sync" button has the following error "Unable to update later - check the layer settings and confirm that you have the privileges to make changes"
The layer has all the correct settings.
Any suggestions please ? Many thanks
