Can someone point me out why two different maps in the exact same area, using the same background imagery (basemap), and same profiles (in both trimble and fieldmaps) show different accuracy levels within field maps. Our Catalyst DA2 subscription is 10cm (=4"), and correctly shows that within the Trimble Mobile Manager. When I open one Map (for Utility A), I correctly get 4" accuracy within fieldmaps as it connects to the DA2 antenna. However for the second map (Utility
, I am only getting 6.9 to 7" accuracy using the same DA2 antenna at best, within fieldmaps. It is the same exact area being surveyed using the same profiles for TMM and Fieldmaps.
I've reviewed the both Web Map settings and have the collection accuracies set correctly. We all have the same version of Samsung Galaxy 4 active tab pro, TMM, Fieldmaps. Features were published using same setup (ArcPro 3.2 to Enterprise 11.2 ). Web Maps shared off same enterprise portal, coming from the same database.
Is there something in the publishing of the features that I'm missing that would skew any accuracy? Both maps are pulling from the same Oracle DB schema and are in the same projection/coord system.
