All,
I am trying to publish a point layer (storm water Discharge Points) to portal. When I went trough the process it returned with:
Server Response: Error code: 500 Description: Internal server error. Message: Service Hosted/Storm_Discharge_Points/MapServer not found
I looked up the error and checked the space on the drive and the if it was read only. There is plenty of room on the drive and the drive is in read and wright mode. what should I check or do next to troubleshoot the problem. I need to get the layer published.
Pro 3.3.1
Thanks in Advance
Laura
