I have a project with two maps. The first map has some layers which are featureclasses in an entreprise geodatabase on a database server and some layers in a local file geodatabase and the second map has some layers in a local fgdb only this one is active by default in the project. The first map is understandably slow to load since I am on a vpn. The problem is the second map is just as slow to activate when I click on the tab even though there are no network layers on it. If I remove all the network layers from the first map, the first map is fast, which I get but the second map is fast too... I don't understand why a map would be slower to activate based on another map that is already loaded.
