I'm using ImageElement and MediaLayer, such as in this example: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=sketch-3d
to upload a png as the map. In the example, they use x and y coordinates. I'm wondering if it's possible to integrate latitude and longitude into the image instead?
If it's not possible to use lat/long instead, are there util functions available to convert x/y to lat/long for different spatialReferences? The only one I could find was in WebMercatorUtils (but I don't think I'm able to use WebMercator with an image/ImageElement)... which leads me to my next question:
Also, is it possible to upload my own image/ use ImageElement with the WebMercator spatialReference? When I set the spatialReference to WebMercator, my custom image disappears and I see a round globe with no map/images, which I guess would make sense since WebMercator is for a round globe..
If it's not possible to use WebMercator with my own image/ImageElement, is there an easy way to convert points between 2 different coordinate systems? (from one that works with a custom image into WebMercator)?
Thanks so much for the help!
