After many many attempts, I am unable to replicate the functionality of idle Detection in geoEvent within Velocity. We have tried any number of nodes and combination of nodes with no luck. CalaculateMotionStatics comes the closest but does not really provide the same functionality and the documentation for this node is ambiguous at best.
Has anyone else found any good solutions?
https://hub.arcgis.com/documents/5d8e3446736d4df299c7c96bc275d561/explore
The Track Idle Detector Processor is a supported add-on processor that can be added to a GeoEvent Service that detects if a unique TRACK_ID has moved more than a specified amount within a given time. For example, if a delivery van is expected to make delivery stops that will not exceed 120 seconds, a Track Idle Detector could be used to alert dispatch personnel if a van is stuck in a single location for more than two minutes (e.g. if they are stuck in traffic or the vehicle has mechanical problems).
