Hi, We are running Enterprise 11.1 and EXB Dev 1.14. The example errors I have are from Edge Dev tools console. We have a handful of EXB apps built the same way different services that run fine. This EXB will load all layers fine usually the first few times and then we get 3 layers (or a combination of 1,2, or all 3 of about a dozen layers) that fail to load. And if you are lucky and you check again they sometimes load while using the app. Anyone understand why this may be happening? See the image attached. Notice on the right in the dev tools window the 3 failed to load layers and then further down the message recreate mapbaseview because layers that previously failed to load blah blah... and you can see in the EXB Map Layers pane, indeed the layers are now there. This is frustrating because it appears to be random when the layer(s) will fail to load and I don't see anything special about these layers compared to others we published.
Looking forward to hearing your feedback!
Thanks!
John
