I have SA1 (Statistical Areas Level 1) Shapefile and this shapefile attribute table contains SA1 codes, and some census information such as total population, and area km2. I overlaid a 1 km2 fishnet grid on this SA1 shapefile. So, one grid cell contains one or more SA1 areas and also some SA1 areas fall into two or more grid cells. Using the ‘tabulate intersection’ tool, I was able to calculate SA1 code areas in grid cells.
I want to calculate the proportion of each SA1 code in grid cells. And then use them to calculate the number of people that will assigned to that segment in the grid cell. Then I add all the numbers in a cell. Does someone know a tool/s that can be used for these calculations in ArcGIS Pro?
