The release of ArcGIS Pro 3.3 for ArcGIS Aviation Airports and ArcGIS Aviation Charting includes new and enhanced tools to further support your airport, charting, data management, migration, and design needs.
New tools
The following ArcGIS Aviation Charting tools are new at ArcGIS Pro 3.3.
Update Aviation Annotation
The Update Aviation Annotation tool has been added to the Cartography toolset. This tool allows you to update complex annotation layers and apply text and annotation scale updates at the same time.
Aviation Abbreviate
A new Annotation command, Aviation Abbreviate, helps quickly solve label and symbol crowding that can come up during automated workflows of aeronautical chart generation.
For example, an annotation feature is selected.
Using the Aviation Abbreviate tool, with the Abbreviated Label selection, the annotation is modified based on the custom label expression code.
To customize the command for your needs, modify the preferences in the Aviation preferences tool.
Enhanced tools
The following tools for ArcGIS Aviation Charting and ArcGIS Aviation have been enhanced at ArcGIS Pro 3.3.
The following list of tools have been enhanced in the Charting toolset:
Generate Airspace Lines
The Generate Airspace Lines tool in the Data Management toolset now supports multiple feature class input.
Prepare Aviation Data
The Prepare Aviation Data tool in the Data Management toolset now includes support for processing order.
Generate Summary Table Data
The Generate Summary Table Data tool in the Data Management toolset now supports polygon input to define chart areas for tabulation.
Export AIXM 5.1 Message
The Export AIXM 5.1 Message tool in the Data Exchange toolset is now configured to export ApproachLightingSystem, ApronLightSystem, GuidanceLineLightSystem, RunwayDirectionLightSystem, RunwayProtectAreaLightSystem, TaxiHoldingPositionLightSystem, TaxiwayLightSystem, TouchDownLiftOffLightSystem, and VisualGlideSlopeIndicator.
Aggregate Obstacles
The Aggregate Obstacles tool in the Cartography toolset now includes support for output features to indicate group status.
The following tool has been enhanced in the Airports toolset.
Generate OIS Profile Data
The Generate OIS Profile Data tool in the Analysis toolset now has support for takeoff_flight_path_area in the Terrain and Obstacle Profile element.
Product files updates
At ArcGIS Pro 3.3, the following changes have been made in the Aviation Charting product data files, which are available for download in MyEsri:
- An HTML document is available in the Aviation Charting product files to compare the ArcGIS 3.2 AIS schema to the ArcGIS Pro 3.3 schema.
New Charting scripts are available in the product files:
- AIXM Checksum
- Create Annotation Feature Class
- Configure Aviation Geodatabase
New Airports scripts are available in the Aviation Airports product files:
- Import FAA NOTAM
Reach out to us at aero@esri.com if you have questions about these new capabilities.
For further information, visit the ArcGIS Pro page or the What’s New documentation and post your questions in the ArcGIS Aviation board in the Esri Community.
