Hi
I have created a custom widget in ArcGIS Experience builder. This widget takes a selected feature from the map and show the attribute information of the selected feature. The widget is working fine. However I want to use it as follows.
I don't want to place this widget in the map, instead I want to launch the widget on mouse click. Like use selects the feature and my widget should popup with the selected feature as a an input property. At the moment when i select a feature, the feature info dialog gets popped up and then i click my widget that is placed on the map. I want to directly launch the custom widget on mouse click and also i don't want feature info window gets opened.
Any help will be highly appreciated.
thanks
