I want to design a survey for respondents to complete on a tablet. It doesn't matter so much where the person is standing while taking the survey. Essentially, the survey will be a series of multiple choice questions (non-map) and then several map-based questions such as a circle or selecting the location (e.g., a building) based on the topic. Is field maps a good choice for this type of survey? Or should I be looking at some other Esri solution? If so, can you point me in the right direction?
Derek
