Running Rocky Linux 9, ArcGIS server 11.2, first server has portal/server/datastore running and is Federated
Second system same version operating system and server they are using the same config-store and directories folders.
when I try to register the second machine on the first machines I get this error
Failed to register the server machine 'granit24a-vm1.sr.unh.edu'. Could not connect to the ArcGIS component at URL 'https://granit24a-vm1.sr.unh.edu:6443/local/licenses'. The ArcGIS component on that machine may not be running or the machine may not be reachable at this time.Error: status code: 404
It is true local/licenses doe not exist but then again don't know why it should.
Anybody have clue on what I should look for next?
