import arcpy
from arcpy.ia import *
arcpy.CheckOutExtension("ImageAnalyst")
in_models = 'C:/Users/GIS Dev/Documents/Riset_arcpy/model_map_space/model_5_epoch/model_5_epoch.dlpk'
data_raster = 'C:/Users/GIS Dev/Documents/Riset_arcpy.ia/Radarsat-2-4978_I005632_FL01-P008585_Scene_1_2023_08_20_22_01_42/tif'
obj_detection = 'obj.shp'
model_args = "padding 56; threshold 0.5; nms_overlap 0.1; batch_size 64; exclude_pad_detections True; test_time_augmentation False"
run_nms = "NO_NMS"
confidence_score_field = "Confidence"
class_value_field = "Class"
max_overlap_ratio = 0
processing_mode = "PROCESS_AS_MOSAICKED_IMAGE"
arcpy.env.extent = arcpy.Extent(113.7975122046781706, -7.7461582880389077, 114.0177164475001632, -7.4046301537038710)
Output_Classified_Raster = arcpy.ia.DetectObjectsUsingDeepLearning(data_raster,
obj_detection,
in_models,
model_args,
run_nms,
confidence_score_field,
class_value_field,
max_overlap_ratio,
processing_mode)
