Hello Experience Builder Community,
I'm developing a "Franken-app" using Experience Builder as a kind of top level interface. Part of the system is an R Shiny app I developed to handle some search functions. I also bolted on a simple report function which gets implemented as a Download Handler linked to a button on the user interface. I then put this into Experience Builder using an embed widget.
The intended sequence of events is as follows: User searches the database and gets results back. The user says, "I want to save this as a report" and clicks the "Report" button. The report button kicks off a function in Shiny which puts the result set into an MS Word document (which will be nicely formatted at some point). This all works fine. Except when I embed this search app in Experience Builder. Here, when the user clicks on the "Report" button, nothing happens. However, if the user does a ctrl+click it all works.
My question is this: Is there a setting in the Experience Builder embed widget which would change the click behavior? If I implement this as an iframe tag in the Embed widget, is there an option I should specify?
To see this in action: go to: https://experience.arcgis.com/experience/a8d5e92fdcee48ea88b5cc73b2fb1ecf/page/Simple-Search . Enter "flood" in the text entry box (it's a term I know will produce results). You'll see a couple items listed. Then click "Generate Report". Nothing happens. Do a ctrl-click and you'll see the function generate a Word doc for download. The naked shiny app is: https://noep.shinyapps.io/dc_simple_search/ . This is all in a very rough state right now so go easy. I need to write some error handlers, come up with a report layout and... so many things.
For those curious, the backend database is a Digital Commons academic repository. The apps interact with it through an API. The main reason I haven't tried to develop this in Javascript or Typescript as a custom widget is my own lack of skill in the languages.That and the lack of infrastructure I have available. I need to get something up relatively quickly so I used what I had and what I had expertise in. Thanks for your feedback and advice.
