When importing data from a sql-database via catalog pane, one has to load all data within the specified table. When using tables with data with complex shapes and several thousands of vertexes per entry, it takes minutes to even calculate the extent. After that one can exclude data that is not needed for the specific project.
It would be better if you could use sql-query to make a selection of entries that should be recognized and loaded in the first place.
