Hello everyone,
I was wondering if anyone might be able to provide insight on how much variation is required in the input field when running an Optimized Hot Spot Analysis? When reviewing ESRI's'How Optimized Hot Spot Analysis works' documentation, the following information is provided: 'The Optimized Hot Spot Analysis tool will check the Analysis Field to confirm that the values have at least some variation.'
For context, I have a dataset for which I would like to run a hot spot analysis to look for statistically significant clustering, and the analysis field is an integer ranging from -3 to +3. When running the Optimized Hot Spot Analysis tool, I don't see any warnings or errors indicating that this level of variation is insufficient; however, I would love to find some additional resources that might address statistical considerations pertaining to variation in the analysis field.
Thanks for your help!
