Hi all,
I'm creating a Network dataset for an entire country using HERE data. I'm using a python script working as follow: first, I create a Network dataset from an xml file template, second the records from HERE dataset are appended (Append tool) to the Network dataset and third I build the network (Build Network tool).
Since HERE data includes about 60 million of records, I use a loop that append data and build the Network dataset using blocks of 5000 records at a time (i.e., the first 5000 records are appended to the Network dataset and the Network dataset is build, then other 5000 records are appended to the Network dataset and the Network dataset is build, etc). Every 100000 records added, I recalculate the spatial index of Network dataset and compact the geodatabase.
Here's my problem: by increasing the size of the network dataset, the execution time increases exponentially (at the beginning 5000 records were processed in about 2 minutes, with 30 million records added after a week of work the execution time is 4 times greater).
What is the best practice for creating and add lots of records (60 million) to Network dataset?
Thank you very much in advance
