Hi All,
Just curious if postgres v13.13 (pg13.13) - latest minor release for pg13.x - is supported by ArcGIS Server 10.9.1.
Esri guideline puts minimum supported postgres version requirement for ArcGIS Server 10.9.1 and pg13.x at pg13.3.
https://enterprise.arcgis.com/en/system-requirements/10.9.1/windows/database-requirements-postgresql.htm
However, postgres latest release [as of 2023-11-09] cites multiple vulnerabilities bwn minor versions pg13.3 and pg13.13, and recommends using pg13.13.
https://www.postgresql.org/about/news/postgresql-161-155-1410-1313-1217-and-1122-released-2749/
Based on Esri's database compatibility guidelines and this forum, minor releases are also supported, for each supported postgres release, unless explicitly stated otherwise!
Can we thus safely assume pg13.13 is compatible with ArcGIS Server 10.9.1? And with ArcPro 3.1/3.2?
Does ESRI recommend acquiring supported postgres installation (for windows) for download from My Esri, instead of postgresql.org ? Is there any potential issue if the installation is acquired from postgresql.org especially when the version needed is not yet available from My Esri for example?
Henok
