Is there a graceful way to exit a scheduled notebook run early (i.e. without raising an exception that looks like a failure)? If we use raise SystemExit() or sys.exit(), it raises an exception which is detected as a failed notebook run. This will cause the scheduled task to be disabled. We've also tried a few other methods (like https://stackoverflow.com/a/56953105) with the same result.
What we want to do is check a feature layer for new records, then skip the rest of the notebook (the next dozen cells or so) if there are no new records. There's no point in re-processing this data if we've already ingested/transformed/exported it as that will waste credits and API calls.
We could wrap every single cell in an if statement that skips it if there's no new data, but that seems really clunky.
