See attached.
It is not totally clear to me how these two settings relate: Options > Map and Scene: Transformation Warning AND Map Properties > Transformations
Even with the Transformation Warning option checked, I do not receive a warning when I add a layer requiring it; the layer's datum is different than the map's datum.
However, ArcGIS does automatically perform the transformation (because I can see that it aligns properly) AND I will now see it in the Map Properties > Transformations list.
Can someone explain?
