I am trying to work through the code example to bulk add users with csv on this page:
https://enterprise.arcgis.com/en/server/10.8/administer/windows/example-create-users-and-roles-from-a-csv-file.htm
The code has not been updated from python 2 to python 3 and I am getting stuck on this error message:
gaierror: [Errno 11001] getaddrinfo failed
The code is below as well
# This script creates a bank of users and roles given a comma-separated text file
# They should be listed in the following format and saved in a file with a .txt extension:
# User,Role,RoleType,Password,EMail,FullName,Description
# John,Admins,ADMINISTER,changeme,johndoe@esri.com,John Doe,Server admin
# Jane,Publishers,PUBLISH,changeme,janedoe@esri.com,Jane Doe,Server publisher
# Etc.
import json, urllib,httplib
# For system tools
import sys
# For reading passwords without echoing
import getpass
def main(argv=None):
# Ask for admin/publisher user name and password
username = raw_input("Enter user name: ")
password = getpass.getpass("Enter password: ")
# Ask for server name & port
serverName = raw_input("Enter server name: ")
serverPort = 6080
# Input File with the Role and user information
inFile = raw_input("Path to comma-delimited text file containing users and roles: ")
# InFile = r"C:\testing\agsUsersRoles.txt"
opnFile = open(inFile,'r')
# Dictionaries to store user and role information
roles = {}
users = {}
addUserRole = {}
# Read the next line
ln = opnFile.readline()
# Counter to get through the column header of the input file
num = 0
while ln:
if num == 0:
pass # File header
else:
# Split the current line into list
lnSplt = ln.split(",")
# Build the Dictionary to add the roles
roles[lnSplt[1]] = {lnSplt[2]:lnSplt[len(lnSplt) -1].rstrip()}
# Add the user information to a dictionary
users["user" + str(num)] = {"username":lnSplt[0],"password":lnSplt[3],"fullname":lnSplt[5],"email":lnSplt[4],"description":lnSplt[-1].rstrip()}
# Store the user and role type in a dictionary
if addUserRole.has_key(lnSplt[1]):
addUserRole[lnSplt[1]] = addUserRole[lnSplt[1]] + "," + lnSplt[0]
else:
addUserRole[lnSplt[1]] = lnSplt[0]
# Prepare to move to the next line
num +=1
# Get a token and connect
token = getToken(username, password,serverName,serverPort)
if token == "":
sys.exit(1)
# Call helper functions to add users and roles
addRoles(roles, token,serverName,serverPort)
addUsers(users,token,serverName,serverPort)
addUserToRoles(addUserRole,token,serverName,serverPort)
def addRoles(roleDict, token, serverName, serverPort):
for item in roleDict.keys():
# Build the dictionary with the role name and description
roleToAdd = {"rolename":item}
# Load the response
jsRole = json.dumps(roleToAdd)
# URL for adding a role
addroleURL = "/arcgis/admin/security/roles/add"
params = urllib.urlencode({'token':token,'f':'json','Role':jsRole})
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
# Build the connection to add the roles to the server
httpRoleConn = httplib.HTTPConnection(serverName, serverPort)
httpRoleConn.request("POST",addroleURL,params,headers)
response = httpRoleConn.getresponse()
if (response.status != 200):
httpRoleConn.close()
print "Could not add role."
return
else:
data = response.read()
# Check that data returned is not an error object
if not assertJsonSuccess(data):
print "Error when adding role. " + str(data)
return
else:
print "Added role successfully"
# Assign a privilege to the recently added role
assignAdminUrl = "/arcgis/admin/security/roles/assignPrivilege"
params = urllib.urlencode({'token':token,'f':'json',"rolename":item, "privilege":roleDict[item].keys()[0]})
# Build the connection to assign the privilege
httpRoleAdminConn = httplib.HTTPConnection(serverName, serverPort)
httpRoleAdminConn.request("POST",assignAdminUrl,params,headers)
response = httpRoleAdminConn.getresponse()
httpRoleAdminConn.close()
print "Could not assign privilege to role."
return
else:
print "Error when assigning privileges to role. " + str(data)
return
else:
print "Assigned privileges to role successfully"
def addUsers(userDict,token, serverName, serverPort):
for userAdd in userDict:
jsUser = json.dumps(userDict[userAdd])
# URL for adding a user
addUserURL = "/arcgis/admin/security/users/add"
params = urllib.urlencode({'token':token,'f':'json','user':jsUser})
# Build the connection to add the users
httpRoleConn.request("POST",addUserURL,params,headers)
def addUserToRoles(userRoleDict,token, serverName, serverPort):
for userRole in userRoleDict.keys():
# Using the current role build the URL to assign the right users to the role
addUserURL = "/arcgis/admin/security/roles/addUsersToRole"
params = urllib.urlencode({'token':token,'f':'json',"rolename":userRole,"users":userRoleDict[userRole]})
print "Could not add user to role."
return
else:
print "Error when adding user to role. " + str(data)
return
else:
print "Added user to role successfully"
def getToken(username, password, serverName, serverPort):
# Token URL is typically http://server[:port]/arcgis/admin/generateToken
tokenURL = "/arcgis/admin/generateToken"
params = urllib.urlencode({'username': username, 'password': password,'client': 'requestip', 'f': 'json'})
# Connect to URL and post parameters
httpConn = httplib.HTTPConnection(serverName, serverPort)
httpConn.request("POST", tokenURL, params, headers)
# Read response
response = httpConn.getresponse()
httpConn.close()
print "Error while fetching tokens from admin URL. Please check the URL and try again."
return
else:
httpConn.close()
return
# Extract the token from it
token = json.loads(data)
return token['token']
# A function that checks that the input JSON object
# is not an error object.
def assertJsonSuccess(data):
obj = json.loads(data)
if 'status' in obj and obj['status'] == "error":
print "Error: JSON object returns an error. " + str(obj)
return False
else:
return True
# Script start
if __name__ == "__main__":
sys.exit(main(sys.argv[1:]))
