Hello!
I noticed a problem with the swipe widget in my app.
I would like to compare several WMS layers added to the map with each other. All the layers in the map app are set as visible.
https://uneplive.maps.arcgis.com/apps/mapviewer/index.html?webmap=a5e54afc627546838c1bbf7fb2ee4c81
However, for some reason the widget doesn't work and only displays the layer that is at the top of the list. Although I have selected other layers available in the map app for comparison.
https://experience.arcgis.com/experience/de49b8b9ae904bdcad141f15457180e5/?draft=true
From what I understand, the leading layers section should activate the layers on the left, and the trailing layers section on the right.
For some reason it doesn't work for me. I would appreciate for any tips or hints.
