Hi,First, I used:IStyleGallery styleGallery = new StyleGalleryClass();I can run my program without error (on my computer). But this require using ESRI.ArcGIS.Framework (need install Arcgis Desktop). And, I can't use for my client computers.So, I used ServerStyleGalleryClass, and I used "MakeServerStyleSet" utility to convert my style file into server style.Then, I used below codes, but I got the error "Error HRESUT _EFAIL has been returned from a call to a COM component" (because after getting Items, styleItems is NULL) IStyleGallery styleGallery = new ServerStyleGalleryClass(); IStyleGalleryStorage styleStor = (IStyleGalleryStorage)styleGallery; string startupPath = Environment.CurrentDirectory; string strFilePath = startupPath + "\\Data\\Styles\\SoDo.ServerStyle"; styleStor.AddFile(strFilePath); IEnumStyleGalleryItem styleItems; styleItems = styleGallery.get_Items("Line Symbols", strFilePath, "Default"); // Return NULL value styleItems.Reset(); IStyleGalleryItem styleGalleryItem = styleItems.Next();
Are there anyone know what's wrong ?Thanks and regards,Tai
