I'm attempting to perform a join between an existing feature layer containing country boundary polygons and an Excel file. The relationship between these two datasets is one-to-many. However, when I use the `AddJoin` function from arcpy, the resulting dataset only has a one-to-one join, and the column names in the joined result are not coming from the two original data sources. I've included a code snippet below for reference, and I'm seeking assistance in understanding what might be incorrect with it.
Code:
xlsx_file_path = input("Enter the path to the file: ")
file_path=os.path.join(os.getcwd(),"MyProject1.gdb",'data_table'+str(int(dt.datetime.now().timestamp())))
arcpy.conversion.ExcelToTable(xlsx_file_path, file_path)
arcpy.MakeTableView_management(file_path, 'table_view2')
feature_layer = gis.content.get('b587ef6d8a5b48e382f5fb8f1ccc46ab')
arcpy.MakeFeatureLayer_management("https://services7.arcgis.com/yxpZft6sXAxt864n/arcgis/rest/services/countries/FeatureServer/0", out_layer='outfeatureLayer')
arcpy.management.AddJoin('outfeatureLayer', 'ISO_A3','table_view2', 'ISO_A3','KEEP_COMMON','INDEX_JOIN_FIELDS')
arcpy.CopyRows_management('outfeatureLayer', "C:/new_19.dbf")
Also please suggest any other function if it is applicable here. Currently I am refrencing to https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/add-join.htm tutorial
Thanks & Regards,
Abhishek Kumar Choudhary
